Rear Wheel Bearing Torque
If these are opposing taper bearings instead of unit bearings then the way to do them IF you have no instructions whatsoever
Make sure outer races have been bottomed out correctly and the seating area was spotless, if bearings weren't changed then forget this
Tighten to a fair torque say around 35lbft, turn hub a few times, tighten some more, turn hub a few times making sure it turns with no rough bits, at this point I would hit the hub with a soft deadblow just to be sure the bearings are seated. By now you want some resistance to turn, if hitting with the deadblow loosens the turn tighten a little more at least until no change is seen by turning and deadblow.
Slacken off and then turn, by this time only the top rollers will be turning, slowly tighten the nut until all rollers are turning but only just.
I myself pay no attention to bearing nut torque at all and always do it by feel
Just make sure to note IF the split pin holes don't line up go tighter but only by a little
Edited by wil440
