Differential gear swap
Hey guys, currently my truck has 3:55 gears and they are terrible for towing with 35’s so I’m wanting to swap to 4:10’s. I can’t find a set that will fit my truck but I found a set out of a 94, my question is will the gears from the 94 axles fit in my 2000 axles? Thanks
When I got my truck, it had 4:10's.  I switched out the gears (and carrier case) to 3:55.  I am quite happy with it now.
I'll give you a deal on my 4:10 carrier case. Your going to need it.
I'll throw in the ring and pinion gears for free. (They were singing, the axle shop that changed out my gears told me they looked worn out.)
My axle is dana 80.  Your is most likely dana 70.   My understanding (correct me if I'm wrong) is the 2nd gen dana 70 & 80 used the same gears & carrier. Interchangable.
PM me if interested
Jerry
8 hours ago, LorenS said:
DANA 70 has 10.5" ring gear, DANA 80 is 11.25".
My humble advice is to stick with gears made for your axle, and that preferably aren't already worn out...
Thanks for clarifying Loren!  From what I understand, a manual trans determines if the truck got the dana 80:
3500 = Dana 80
2500 Auto = Dana 70
2500 Stick = Dana 80
If anyone needs a good used Dana 80 carrier for a 4:10 gear set, PM me.  Including the gears for free, but would not recommend using them as I was told they are worn out.
That's my understanding, as well - at least for 2000 and up.  That may be applicable to all 2nd Gens, I just don't know.
Of course these trucks are old enough now that it's worth checking EVERY axle; I'd love to put a DANA 80 in my auto 2001 simply because I like the gear-style limited slip diffs, and no one that I can find makes one for the Dana 70. :shrug:
I have 3:55  and slightly smaller tyres at 33" and if I lock the trans out of OD my rpm is around 2250 at 60, tows nice, egt  low enough, could do with rpm being a little lower for me, 2100 would be nice
