- Replies 10
- Views 4.2k
Sycostang67 3 posts
Mopar1973Man 2 posts
Silverwolf2691 2 posts
Me78569 1 post
For daily driving, honestly, stock or a 178/208 at most is all you need. Big turbo or racing is when the famous 188/220 comes around to help spool turbos. It also pulls the power band up higher in the
To me, i think it will be too big of a cam. S300 and 7x009s arent big enough in my opinion to need that big of a cam. You are also mentioning not needing the rpm capabilities of it. I just dont want y
I was watching some videos last night and had a thought. For the cost of the cam and leaks getting fixed, I could just get the leaks fixed and get a compound setup. The price difference is negligibl
My truck has a small oil leak, just a drop or two at a time but I was told it appears to be from the back side of the timing cover. I'm contemplating having the leak fixed and I figured if the cam has to come out to do it, possibly toss in a different one. I was looking at the Colt cams stage 3 or Big stick as I think it was called. Is anyone using one of these or know someone who is? Just curious if it was worth it.
Just saw the other post regarding the big stick, lol.
