Lifter Access Panel
I suppose injector lines in the way, the old fuel pump bracket, can that be removed? I guess once you start removing injection pump it becomes more clear. I just had injection pump off and as luck goes it wasnt leaking bad. It just started pouring oil a few days ago. I tried to tighten but no luck. I also thought of making tabs that act as bigger washers to pull down in a greater surface.
Edited by jlwelding
