 I'm talking about the line on the rear of the cylinder head. I was under there fir something else yesterday and noticed it's wet on the back of the engine and down the bell housing. A small drip was handing on the bottom of the bell housing. It was fuel. Could see the light green color.
 I took my phone and tried to get a pic behind the head (it's tight back there) and it looks wet. Can't tell if it's just the copper washers leaking or if it's the line itself. So far its a small leak, just a drip.
 Could this cause a slight hard start issue? I noticed yesterday morning she seemed to start a bit harder than normal. (Temp was low/mid 40's)
 Thinking of just replacing the line, banjo and washers also whatever seals at the "T" as well.
 Any thoughts?
 See pics, best I could do in that small space.
2 hours ago, Doubletrouble said:
Should I just do the seals or is it common for the line itself to go bad?
Typically the sealing washers go bad. I've had to replace a set on mine awhile back. No issues since. Typically the line itself doesn't go bad but the seals on the banjo bolt or the square cut o-rings at the return tee fail.
Posted (edited)
Did that one. You have to hug the engine with your head resting on the cowl.. Have a photo of me doing that somewhere.. Best to remove the hook point for a hoist as well.
edit: found it. Me 5 years ago..
Edited by Silverwolf2691
The ol' Cummins bear hug to change the return line seals. Yes removing the valve cover works just a we bit better being you will have a bit more room to reach down with big paws. Sad to say I've got big hands and some thing just are hell for me to do but I still do them.
 Got the seals replaced today. Have to say it was much easier than I thought it would be. I removed the valve cover (and the one heater hose to allow pulling the valve cover off easier)
 So far no leaks apparent,  I used brake cleaner to spray off the top of the bell housing the best I could. I'll check it again after a few days.
