Looking for Staff Members
Thinking of getting some of these Injectors,thinking mine are due to be replaced. I'm sure i'll notice a increase in power,but more important what can i expect in mileage increase.
  • Replies 33
  • Views 15k
I saw only 0.5-1.0 mpg increase. I didn't do a LOT of testing with them before I pulled them for another issue - but it was a pretty consistent test going home and back on a 4 hour trip.
i got me a set:thumbup2: brand new still in the blue plastic package in the yellow bosch box.traded a contractor out at work a puck for an 03 for them...he wanted it and i wanted the rv275's he just got it..so happens he has an 01 also.can't wait to get them in.:thumbup2:
98.5-2002 Dodge 24 Valve Cummins Bosch RV275HP Injectors
1998.5-2002 (24 Valve Only) Dodge Cummins 5.9L NEW 275hp 24 Valve Injectors.
Add up to 40HP to your 98.5-2002 Dodge Cummins Turbo Diesel!
Bosch Part Number: 432193635
Includes copper sealing washers & new o-rings for the injector connector tubes.
Set of 6 injectors, no core charge.
Increases the power by 50 horsepower and 100 lb-ft of torque at the ground on '98-'00 automatics. These same injectors add 33 horsepower and 66 lb-ft at the ground on manuals and '01 automatics. Throttle response and low-end acceleration are definitely improved with this addition. Fuel economy normally improves by 5% with this change. Injectors can be installed within about 3 hours by most do it yourself enthusiasts. These are new Bosch® injectors approved by Cummins® on their 275 hp 660-torque motorhome engines.
These injectors do not wash oil off cylinder walls and dribble at idle like some aftermarket injectors that are modified Bosch® injectors. Some 1998 24 Valve trucks need connector tubes with these injectors, these trucks have an engine serial number below 56462591.
THESE INJECTORS ARE ON A NATION-WIDE BACKORDER!
this was from puredieselpower.com site.
Need more Horsepower for your 1998 to 2002 Dodge 24 valve engine ?
[*]<LI class=style62>This is a set of 6 NEW Bosch 300 HP injectors Bosch part number 0432193635 <LI class=style62>These are Marine Injectors specifically made for the Cummins 5.9L 24 valve ISB engine. <LI class=style62>These are brand NEW not rebuilt or used... <LI class=style62>These come with a ONE year unlimited mile Warranty!
[*]These are set to give you up to 40 MORE HP!
rv275's
what are the hp gains from these and would it benefit me to pull my 125's and install these. would i gain better mpg's with these compared to my current injectors???
ok so do you think the mpgs would get better running these as opposed to the 125s i have now
Anytime the tach needle pass the 2K mark you can garantee a loss of MPG instantly... Like for me to run 55-60 MPH I see 20-21 MPG everytime... But now to hit the interstat and run 75 MPH which now puts me at 2,200 RPM now I'm down to about 12-14 MPG... Funny... If I stay in 4th gear (1:1 ratio in the trans) and go 45 MPH which is roughly 1,900 RPM's I'm clearing over 25-28 MPG :stuned: But of course that's with 3.55 gears...:rolleyes: The other factor is going from 55 MPH to 65 MPH the wind drag nearly doubles... :wow:
That whole 2000+ RPM thing being instant drop is a bunch of crap. I know everyone preaches it on every forum but I have never seen an instant drop. I do 70 at 2100rpm and get 21mpg doing it. I got 17mpg pulling the trailer at 70 also. Speed kills MPG, not RPM.
That is a mystery I can't answer between the 2 trucks... :shrug: Like if I go down to Boise, ID and hit the interstate and drive speed limit everywhere I'll see roughly 16-17 MPG. But now if I avoid the interstate and use all smaller roads and keep my speed down (RPM related too) then MPG's natural rise for me... Now the only thing I could say that might give a clue tha P-pump's don't advance/retard timing but I know that VP44 do retard timing at high RPM's post-2-138698172314_thumb.png As you see for me running high up the RPM scale just retards timing... :rolleyes:
I've yet to see > 18mpg, ever, in my vp44 truck. My average DD mileage in the 24v is ~14-16mpg, all city. My p-pumped 12v (turned up) saw 18-20mpg in the same usage.
In my 12valve, from Virginia to Long Island, NY, we got 26.9mpg @ 68mph on the way there. On the way back, @ 72-73mph, I got 22mpg. empty, no trailer. My 24v gets ~17-18mph @ 65mph, empty, no trailer. 12v = #10 fuel plate - FF, AFC-FF, 40psi, 16.5*, 4" dp, catless/mufflerless 7" stack, bhaf, nv4500, 241hd, 3.55s, jake 24v = stock everything except bhaf, 5600, no muffler/resonator, 4" turndown behind cab.
That is a mystery I can't answer between the 2 trucks... :shrug: [ATTACH=CONFIG]2093[/ATTACH] As you see for me running high up the RPM scale just retards timing... :rolleyes:
What software is that map from??
There was a guy that managed to tap into the Cummins ECM with a program called ROMRaider and this is one of the few pieces of information I captured before his site went down.
I thought it looked like RR..Thats what I use for tuning Subarus..now, I'm gonna have to start digging a little ;) I've used RR since '07.
i believe it is the rpm's over mph.lets say 3 truck testing..going 65 or 70..this is for an example here...3.55 or 3.73 or 4.10..whatever.....automatic,5-speed,6speed.....and one of them has a gearvendor over/underdrive unit on it.....one truck at 70 is spinning 1900rpm....one is spinning 2100..one is spinning 1600 rpm..i would want the one that is spinning the fewer rpms..wouldnt you mopar??:thumbup2::smart:
http://www.gearvendors.com/index.html
http://www.gearvendors.com/faq.html :smart::thumbup2:
have you gotten your injectors yet?:thumbup2:
I've yet to see > 18mpg, ever, in my vp44 truck. My average DD mileage in the 24v is ~14-16mpg, all city. My 24v gets ~17-18mph @ 65mph, empty, no trailer. 24v = stock everything except bhaf, 5600, no muffler/resonator, 4" turndown behind cab.
Funny - those figures are almost exactly the same as mine before I added my juice. Now ...... +1mpg towing (11-13mpg) ........ +1mpg city (15mpg-17mpg) ....... +3mpg highway (20-21mpg). When I add my RV275's back in {probbaly live with the stalling for now} ....... I expect around +1mpg extra to each of those figures.:woot:
Yeah kinda agree on this one. Interesting about the winddrag factor above 55mph (is that figure right mike ?) and the vp44 retartment with rpm. But I hit 20mpg on 65mph cruise control every time. I don't think I am going to see 24mpg running her at 55 mph ..... :shrug:
