This is the most annoying problem I ever had. It is the torque converter locking and unlocking. Mine has done this many times. Try to fix it soon as it puts a lot of stress on the input shaft when this is happening. I killed a tranny this way. You can try resetting the appps and see if that fixes it. You can check all the grounds. You can replace the apps sensor. You can add a noise isolator. I bet if you did those things it would fix it.
Mine does it at 30 MPH with light throttle at a steady constant speed. With TPS at 24.3% and if I add a little throttle to 26.5% it'll do it. Same when I let off the throttle it'll do it again.
Very annoying, I must say. Seriously debating on the quick fix.
How would resetting the APPS fix this?
