- Replies 10
- Views 3.1k
Mopar1973Man 4 posts
dripley 2 posts
flagmanruss 1 post
MarbleCrusher 1 post
Well Gang...
I finally got my feet wet and modified my Jayco Eagle my way. I added a battery cutoff switch and a true battery volt meter. It all tucked away in the power cabinet so its out of site out of mind. Bjut the reason for putting the cut off switch in the cabinet was I could take my trailer out to a camp site in the wood and park it and lock it up. I can shut down the power and know when I return that no one has tampered with the power because its locked up inside. Like I've see lot of idea where the battery cutoff is on the battery box but I was looking for a secure way. Also in the design of all this I set it up so if I'm hooked to 120VAC I can still keep the batteries charged but shut down all the 12VDC loads and keep the trickle draws locked out. So in the power cabinet was the best place. Now I can check the status of my batteries a bit closer to real value than the simple 4 LED's on the panel in the kitchen.
My handy work...
