- Replies 7
- Views 2.2k
CUMMINSDIESELPWR 3 posts
Mopar1973Man 1 post
JOHNFAK 1 post
dripley 1 post
So i recently installed some new rv275's and love them. However i need to rebuild or replace the turbo as i have high temps most of the time cruising at 65 no load or towing. I do need to test for air leaks but i am pretty sure i dont have any. At stock setting it will run 700-800 any setting above stock and im easily hitting 900+ when i step into the skinny pedal. on setting 5 it will make the turbo sing and barely the 30 psi i have it set for defuel but i can easily get it over 1200F if i want but dont like it. I do get a lot of smoke on the bottom end of each gear but once the turbo is spooled its not bad if any at all. the lag on the stocker is long though... It is stock turbo, BHAF, it does have a bit of radial play, no front to back shaft play and has never been off the truck in 175,000 original miles. Does anyone have a stock HX35 they want to sell of give away? Would it be better to upgrade to a garrett turbo http://www.thoroughbreddiesel.com/garrett/759361-0002.htm i have an exhaust brake that fits to the stock downpipe, not sure if it will work with a different turbo. i dont want to lose it. what say ye oh wise men of the cummins world? Rebuild stock turbo? $80 replace with garrett? $2000 upgrade impeller or compressor wheel? $ ??
