sigh... long start when hot again...
Interesting. Never ever would have thought that...
Whats the crossover tube and whats it do? :lmao2:
Actually I wasn't. I never knew that part had a name. :ashamed:
Ok. Just for you CSM
Connector tube (or crossover tube) is the tube that connects the high pressure line to injector. Inside the crossover tube is a filter called a edge filter. This filter takes small debris particles and beats then in the funnel shaped V's till the debris is small enough to pass-through the injector. On 12V's the edge filter is part of the injector body.
I have a theory on what was going on here. The connector tube o-ring seals out air from getting into your fuel system. So if you have a bad one it lets air bleed back your fuel. You cannot measure air molucles(sp) so you can have an air leak but no fuel leak. Usually if you have a bad connector tube o-ring it will be hard starts cold and start normal when the engine is warm. I would have to look at he injectors to see if there is actually fuel return going past the connector tube but Im thinking that the o-ring on the injector blocks the return fuel.
Same issue with my truck. You can't see any fuel leaks but air would get in. I actually cut all the metal lines and used swagelok fittings to eliminate the stupid banjo bolts, problem solved.
ive had the pissing fuel from old orings before, this time with a visibly failed oring it was pissing and sucking air, very fast ill add! so you can have a combo of these... pissing sucking pissing and sucking (and no im not describing a porno LMAO
