- Replies 8
- Views 5.6k
Hawkez 2 posts
Mopar1973Man 1 post
Rogan 1 post
dripley 1 post
Hello, I am getting ready to install Fuel Pressure, EGT, and a Boost Gauges in my truck. My question is about thread sealant on the treads of fittings and senders. I am going to install a tapped banjo bolt on top of my filter housing and a needle valve will be installed in that. I don't see a lot of recommendations for Teflon tape and I am not sure if I can get a good seal without adding something to prevent leaking. Does anyone have any suggestions? For the EGT gauge I was planning on using an anti-seize on the treads of the sensor. How about for the boost sensor? Is anything recommended for that connection? Thanks for your help.
