New injectors, possibly this weekend..
When the guy I work with put the 370 marine injectors (5x0.012@155°) in his truck it did the same thing yours is doing when it was cold out. he was running stock timing as well.
A lot of times they will lope slightly when cold. Mine with 16.5* timing and 300 injectors has a slight lope cold. Rogan, yours sounds more like it is in the 20* timing range though.
I don't have a  tractor that doesn't lope  when cold,  (stone cold @   32  or  less)   either   NA  or  turbo'd.     JD,  perkins,  or  cummins.... they do it all.
how is  yours  starting..... does it  crack right off,  is it  'fighting' the starter?
your  4000 psi  =   275 bar..        Sounds about right to me.
when's  the last time you  checked your   turbo?
Edited by rancherman
The level of sound comes in large part from the type of air filter/intake set up i think. I know when I switched from my AFE cold air filter to the BHAF the turbo whistle became almost nonexistant. It was real noisy with the AFE but it went completely away with the new filter. The AFE was a very thin air filter I think.
well,    your  nasty  fuel economy  gotta  be   something  other  than the injectors...   cause   it's  basically the same  with   either set of  injectors.
how long  has it  been this way...  did it  come on   suddenly.. or  gradually   sink...  or  been this way the whole time?
Have you ever had your truck next to another 12V and noticed that one truck has a 'harsher' sound when idling? That is timing. The higher the timing the harsher the sound. Yours to me (in your video) sounds a lot like the timing is set way to high. Have you checked the timing?
Gosh, I remember when it was just as simple as taking a timing light and turning the distributor on a gasser...
Yea, I used to do that sort of stuff for a living. That and change the points, plugs, and condenser.
