Acronyms Feature
Ummm... I'd have problems with those and the bad word filter here.
PITA the A is blocked
POS the S is blocked
SOL the S is blocked
SOB the B is blocked.
If any of those are considered bad words we better all quit talking, I hear grade schoolers using these words as common vocabulary now days with out anyone questioning it. :think:
My mother in law uses these words and she is about as conservative / christian as they come and is the first to chew out anyone who uses any bad words.
Not sure now how to describe my mornings first order of business or what to call the animals on the farm. :evilgrin:
Edited by Wild and Free
FUBAR………………….since many of us are "do it yourselfers"
IIRC……………………..if I remember correctly
DW………………………death wobble;  not Dorkweed
FF………………………..fuel filter
LP……………………….lift pump
HNIC…………………….the guy in the White House
FUBAR ………………….since many of us are "do it yourselfers"
IIRC ……………………..if I remember correctly
DW ………………………death wobble;  not Dorkweed
FF ………………………..fuel filter
LP ……………………….lift pump
HNIC …………………….the guy in the White House
IIRC
LP
Already got those remember CAPITAL and a space. The only reason Dorkweed's didn't work is the period right after.
Not that I care but believe it or not it does impact the search engine and how they consider your site. If you rank high enough for bad words you might be classed as a porn site or adult site which would have some impact on a bunch of people here who access the site from work or Gov't places. I've been down that road long ago some how one search engine classed us as a Adult site and it took some effort on my part to get us removed from that title.
DD        daily driver
4x4          four wheel drive
4WD        four wheel drive
2WD       two wheel drive
CAT        catalytic converter
KITTY       catalytic converter
BHAF       big honking' air filter
MOD        modification from stock
MOD       forum moderator
MTF        manual transmission fluid
ATF        automatic transmission fluid
TP          toilet paper
AR          zombie protection
AK         more zombie protection
NODAK      North Dakota
EGT                 exhaust gas temperature
RP                     rail pressure
AT                         all terrain tire
MT                       mud terrain tire
DP                       drive pressure
FORD                      found on road dead
FORD                    fix or repair daily
FORD                      finally own ram diesel
