Pristine CTD. Extra cab, short bed, 2wd, SLT. Factory tow/haul package, leather heated seats, heavy insulation package. Rebuilt HX 35/40, Dap injectors, full gauges, PacBrake, Dynamic Transmission vb/servos/accumulator/strut/band/triple disc. Soft tranny lines, 40k trans cooler, lift pump, gooseneck hitch (never used), class 5 tow hitch, tonneau cover, air bags, re- geared to 3.73’s, 3rd Gen brakes with 17" rims Rust free CA truck located in Chico CA, 100 miles north of Sacto. I built this to
Price: 16000
I finally got time to change out my leaking(severely that is)tappet cover gasket. I just made a 1600 mile round trip and went thru near 5 quarts of oil. While in the past I have removed every thing form the drivers side of the engine at different time, it was the first time I ever had to remove all of them at once. Pretty much stripped everything on the drives side to gain good access to the block. The only thing I left on was the fuel lines for 3, 4, and 6. Just did not want to mess with the lines at the head. They did get in the way a little but not to bad. It was also the first time I dd the VP by myself. Of everything I dealt with, that worried me the most. It all went back together fine. Primed the fuel system and got her running in about 5 minutes. Took her for a test drive and pulled into a parking lot and found one leaking fuel line at the head. A quick turn of the wrench, problem solved. The beautiful thing was no puddle of oil like I have been seeing for a while now.
When got the tappet cover off I was surprised to see how bad of condition it was in. It was completely hard and had cracks in it all the way around. When I took it off the biggest piece that came off was about 6" long. The rest of it came off in 1" to 2" pieces. I probably spent no more than 1 hour removing the cover, the gasket, cleaning it up, installing the new gasket, and bolting the tappet cover back on out of the 2 days I worked on it. For now it was all worth it. Keeping my fingers crossed I installed it well and they will be no problems until this one goes out.
I did have 2 glitches with the install. #1 When I took the filter canister our I disconnected the fuel line and wedged the fuel line up in the fire wall somewhere. Evidently I knocked it loose, then tool a break and ate some lunch. When I came back out and started back to work I dropped a bolt. Thats when I noticed the fuel line on the ground dribbling fuel. Got it back up and zipped tied it up. Since the ground was wet from the morning rain I just did not see it. I could not tell you why I did not smell it. I noticed a fair amount of wetness this morning and noticed it was green. Lit a paper towel and put in the small puddle and the puddle caught on fire and burned for an hour
. After getting the truck up and running it looks like I lost about 6 or 7 gallons of diesel. I bring this up not for the cost of the diesel but you just dont need to pour it on the ground. Its just not a good thing to do.
The other problem is now my Scan Gauge does not work. It was working fine before but is dead as a door nail now. Not sure what is going on there, and I ran out of time today to look into it. I am open to suggestions though.
Any way I want to thank all of you here who continue to give me confidence to tackle projects like this. I have by far done more things to this vehicle than any I have owned before. Yall have allowed me to learn and pass it on to others for there benefit.
The chicken man and his truck say THANK YOU!!!!!!!!!! I am no longer lubricating everything I drive on.
