- Replies 10
- Views 5.3k
Dieselfuture 5 posts
dripley 2 posts
JAG1 2 posts
Mopar1973Man 1 post
Just got Draw Straw 5 from Vulcan to help with 1/4 tank sucking air problem. I got an upgraded in tank fuel pump module. This kit replaces in tank pump with clip in aluminum fitting and flex hose to top of sending unit. Then it says to replenish fuel back to module I need to use factory outlet (that's not used anyway) as return a quick connect that is 3/8 and new fitting is 3/8 to 1/2 barb. Before I did this my return was going to filler neck. So now that I got it all plumed according to instructions my fuel pressure went up to 22 where before it was 19. The only thing I can think of is restriction in return going from air dog to module, the actual hole in module is just over 1/4 where before it was just dumping it in filler neck with no restriction. Anybody had this problem ? and what did you ended up doing? If I return fuel to filler neck it will defeat the purpose of doing this kit, as Air Dog will suck module dry.
While doing this I found return line from vp and injectors kinked off, just 8" down from quick connect on module. It was bent to about 45 degree angle. previous owner must off took fuel tank out to put in draw straw that came with air dog and when putting tank in pinched off return line. So I don't think there was much fuel if any returning for a while now. What problems would this cause? Any opinion is appreciated.
Also does anybody upsize return lines and fittings from vp and injectors?
