both of the lines on the drivers side have delevoped abrasion leaks.
I can find one replacement line: DORMAN 324-353, the other is NLA
I want to replace with AN style lines or equivlent. What have you used if you have done this mod?
Posted (edited)
If you want the most reliable and probably the most expensive is this:
find a hydraulic line shop that makes lines for anything and everything the group I used was call hyquip I spent about 300 for every single cooler line to be made out of a product called blue braided- basically material what you would find on a cat front end loader.
Install and don't look back.
I know it is probably overkill but my reasons where simple I spent one year hauling equipment from Wisconsin to North Dakota one time I blew a cooler line 400 miles from home around ST Paul.  I was stuck in a hotel for three days with my truck trailer and a brand new transmission with less than 5000 miles on it paranoid I screwed it up I had the shop that did the work tow it to a shop of there's in Lacrosse.  They fixed the lines and I preceded to drive home, except I didn't make it about 150 miles from home the other line next to the first one that goes to the water to oil cooler on the block blew.  Stranded again it was towed all the way to there shop and fixed this time with copper lines hoping flexibility would win.
 if you guessed I'd blow those in no time you would be correct they lasted two months, so I went to the Dodge dealer and said WTF and  my friend who works there recommended me to hyquip and said his charger and all his buddy classic Mopars get plumbed by these guys went there with my fittings and lengths of hoses needed and they were done in a day
As far as the transmission shop Dunhams they then installed these lines for me free of charge as well as covered all other costs on everything else down to the rental car that I drove home great shop in my opinion
Sucks I just put the cab back on otherwise I could have gotten better pictures I will post in an hour or so
Edited by MoparFreak1988
Use a propane torch to warm the area around the fitting that broke. Then use the easy out.
of course my easy out kit is missing/lost the right size!!!! go figure.
the fitting is righ on the transmission of course. back in 2 hours after a trip to town
You should be able to get the fittings at just about any auto parts store or a tranny shop.
Wow, this is the second complaint about NAPA lately....... I hope is isn't a trend.
All in the area have to order. NAPA, O Reily, Auto Zone, Advance, HArleys (local independent) really really sad state of affairs. lots of mudguards, steering wheel covers and curb feelers in stock though
Posted (edited)
Just to make sure any new hoses and fittings will withstand the psi, What pressure levels are we talking about?
Also... would it be possible to place a inline canister type filter on the lines and get rid of the factory filter? Probably not much benefit since you should drop the pan anyway to adjust the bands
Thanks, Mike
Edited by JAG1
I just took my 47re auto trans out of my 99 Cummins 4x4 and installed a NV4500. I have all the cooler lines still as I took them all off with caution because they weren't leaking and I bought the longest one from Dodge for $151 a year and half ago. Which lines do you need? The only lines that I cut were the two rubber lines that head to the trans cooler in front of the radiator on the driver's side.
Let me know.
