- Replies 20
- Views 8.9k
tonyjsan 7 posts
KATOOM 4 posts
Mopar1973Man 3 posts
rancherman 2 posts
About a year ago I had the clutch replaced, went with a South Bend DD, I pull a 14k 5er, so this is the clutch I was advised to get. In retrospect, not sure I'd ever get another south bend, clutch is so dam temperamental, and seems to really suck when the humidity is high, lots chattering.
This leads me to the main question, since this clutch was installed shifting gears when moving there is noticeable "resistance", it's worst trying to get into 3rd gear, if one pushes on the stick to hard it will grind bad (did not have this problem with stock clutch, but I did notice with stock clutch, that 3rd gear would grind once in a blue moon, I just figured I had screwed up the shift). The time it takes to get into 3rd gear is enough for someone to crawl up my rear, during city driving, I can not dart into traffic or if I need a quick maneuver of speed / power from 2nd to 3rd is impossible, as can't get into 3rd gear in time.
When moving 4th & 5th gear are ok.
When at a complete stop engine running, 2nd is hard to get into, I have to hit 4th, then 2nd.
One more odd item sometimes when shifting while moving, if I goose the engine just as I push the stick into a given gear, at the same time I feel the "resistance" seems like the gear is "sucked" in, hope that makes since.
Synchros going out ? rebuild time ? New tranny ? It does have 210,000+ miles.
Thanks
Edited by tonyjsan
