- Replies 22
- Views 9.7k
MoparFreak1988 6 posts
MnTom 3 posts
Dieselfuture 3 posts
Killer223 3 posts
So I have a plow that has been around for about 14 years it is an old boss v plow I have mounts for my truck and a ford theses are two separate factory made mounts for the rt2,,, I plan on setting up both trucks for the plow mine as a back up for when the ford breaks down. I have done this before and understand that my plow frames are bolt on items for both trucks but still require drilling a couple holes in the frame for example Boss says for the push bar rear support to drill 3, 9/16 inch holes in a 4 inch x 4 inch area now I know why those bolts are there but my question is would one 4 inch bead of weld that can be ground off be better than Swiss cheesing up the frame? would it be just as strong?, now to give you an idea of strength before these last 6 bolt go in or it is welded there is a total of 16 other bolts holding it all together...
