Lift pump diagnostic help needed
- Replies 39
- Views 7.6k
dave110 12 posts
Mopar1973Man 6 posts
hodag56 5 posts
rancherman 4 posts
I have a lift pump issue I am chasing. Now before you tell me Raptor is junk, get a FASS I switched to my spare pump today and still the same symptoms so I'm ruling the pump out for now. Most of the time when cold I'll key on, hear the 1sec pump run and away we go as normal. Pump always holds 18 psi once it's running. When the truck is warmed up and I shut it off for a few mins. and go to restart, most of the time I hear a clunk, clunk, clunk from the LP. After that sometimes it will run and sometimes not. I usually bump the starter until it does run and then start. Once running it never shuts off and hold good pressure. What makes it hard to diagnose is that it does not always repeat. Today after switching pumps out I went for a drive to warm up, brought it back shut off and bumped the starter and clunk,clunk,clunk. Till I got my meter set up and went under to check for voltage I bumped the starter again and the it worked fine. I'm thinking either bad relay or ECM not triggering as it should? Thoughts and how to test?
