Cross over tube o-rings
- Replies 17
- Views 4.1k
mehbohdi 4 posts
Mopar1973Man 2 posts
dave110 2 posts
CUMMINSDIESELPWR 2 posts
So I'm going to replace X-over tube o-rings and I have conflicting info, Book says torque injectors install tubes torque injector lines, I have read on this forum leave injectors loose (snug but not torqued), install tubes, torque lines, then torque injectors? Is one method better than the other? I understand reasoning, to help center tube on injector. Is the book overly confident that one could put the injector in the proper position the first time? I want to hear from people that have done it. Thanks
