not firing but have prime?
- Replies 42
- Views 9.4k
rburks 15 posts
Mopar1973Man 11 posts
hex0rz 5 posts
dripley 4 posts
Okay, so I have been having trouble with the truck recently. If I let it sit longer than a day, I have to cycle the lift pump to prime to get the truck to fire. Takes a couple tries before it will fire too.
If I drive it daily, no problem. I've posted recently about this sort of problem.
Today, I primed by cycling the lift pump doing a bump start. Cranked and tried to pop off once. Every time after, no go.
So I primed 3 times no go. Then I cracked the injector lines and primed multiple times, no go. I've done everything I think of to try to get it to fire. I have fuel supply to the injection pump, but anything after the pump, dry.
Scan gauge show no codes. Is my injection pump giving up the ghost?
