Rear End Help. Dana 70-2u
- Replies 20
- Views 10.9k
djharby 7 posts
Wild and Free 3 posts
CSM 3 posts
Dieselfuture 2 posts
Ok, I have an 2001 4x4 2500 eclb 192k power lok. BOM tag is gone and it has had a diff bearing change, one side is koyo other it timken. My rear end is stamped D702U.
First off what is the 2U and I pulled it apart I have a pinion bearing going and found out that the spider gears were looking bad and the clutches for the lsd are toast. When I pulled the diff there was no shims on either side. does that sound correct at all?
