Help....Know just enough to be dangerous and having problems
- Replies 65
- Views 11.5k
Vais01 18 posts
Mopar1973Man 13 posts
recondoc 9 posts
dripley 7 posts
Howdy All,
I have a 2wd 01 2500 5.9 with very few modifications. Primarily an Airdog Raptor FRRP a K&N filter and a 5" turbo back exhaust. I normally run 1oz/gal of Walmart 2 stoke oil in my fuel and my truck as been an absolute workhorse and has run super smooth....until this morning.
I filled up with fuel yesterday and ran about 65 miles. This morning, I headed out to the hunting property. As I got onto the highway and accelerated, my truck started "stutering" (for lack of a beter term) as the RPM climbed. I pulled off of the highway, and put the truck in neutral. With the truck in neutral, I slowly reved the motor up to 4500 RPM and it went up nice and smooth. I put the truck back in gear and took it over to my local O'reilys just to be where I could get stuff if necessary. I first checked my transmission fluid thinking that it might be that. It was a little bit low but not much. I added 300ml just to be on the safe side and headed back home. Shifts were still erratic and the truck was still stuttering.
I spoke with a good friend over the phone and he mentioned that it could be a fuel issue. I pulled the fuel filter to give it a quick look and didn't find anything glaring or big in the filter or in the fuel drained from the bowl.
I went in to read a few articles on what it might be and someone mentioned that, even if you just changed the filter recently, try putting a new one in. I decided to give this a try and hopped in to go up to my local NAPA around the corner from the house. BRAIN FART!!! I forgot to reprime the bowl and fuel system before driving. Needless to say, I ran my VP and cylinders dry....ARRRRGH!!!!!
I pushed the truck back home, broke loose 1,3 & 4 and commenced to restarting the truck. It took a bit longer than norma but finally caught and ran rough, as it has in the past when repriming. I tightened up my injectors but it never smoothed out. I cracked 1&3 loose again and let it run rough of a few minutes to push air out. Re-tighten again and nothing. I bumped my starter and bled off the pressure test port on the VP44 to ensure that air wasn't trapped there. Restart and I have a smoother idol but ZERO Pedal....Dead.....Deceased......PUSHING UP THE PROVERBIAL DAISIES!!
I attempted a ECM reset for pedal top/bottom but it makes not difference.
I finally decided to stop doing anything further with it until I had a chance to hear from folks who know a lot more than me.
Current state is that it will idol smooth at 800rpm but pedal might get it to 9-1100rpm max and it turns rough rough rough.
PLEASE GIVE ANY ADVICE YOU CAN. I got laid off from the oilfield last month and really need to have a running vehicle to have any chance at finding work again.
Any and all help is highly appreciated.
Thanks,
Doc
