XRF Balljoints
I know this has been beat to death over the years but I have a question. I never considered XRF because I thought they were high priced but checking I see they are cheaper than NAPA and OEM Spicer. Are they any good?
  • Replies 110
  • Views 20.6k
Hmmmm.. where did all my pics. go? Here they are hopefullypost-532-0-33441700-1443721771_thumb.jpg]post-532-0-13967300-1443721584_thumb.jpgpost-532-0-13967300-1443721584_thumb.jpgpost-532-0-39480600-1443721613_thumb.jpgpost-532-0-22533100-1443721671_thumb.jpg
Edited by dave110
Yeah, Nobody in any other state needs to tell me about road salt. PA. has got to be the worst.
Probably why the Amish still use a horse and buggy  :sofa:
Ha, Ha, but seriously, the road salt does wreak havoc on the wooden buggy wheels and steel rims. Salt shrinks the wood and they need to refit the rim on. Blacksmith has a special tool he showed me to do the job. Kinda makes ball joints seem easy :)
I hear you there. Salt dries up just about everything and swells steel up with rust. Seems a great solution would be to paint everything once a year.
Now I am curious to see this wagon wheel tool.
I've already posted Weiser Idaho salt pile.
The only thing I can suggest is getting a small hone stone/brush and lightly hone out the ball joint holes to clean them up a bit. Also make sure to coat the holes with anti-seize so maybe next time its not so bad.
As for rust even though Idaho pours the salt and stone down on the highways. I lucky so for to keeping the rust at bay.
Getting the joints out was really no problem. Much easier than I thought. It's not the rock salt that's so bad but the liquid pre- treat they started using a few years back. Sodium hydro chloride or something. All the DOT trucks have a big liquid tank on the back now and what ever that stuff is eats vehicles for breakfast, lunch and dinner.
Sounds like the mag-chloride colorado uses...nasty stuff!
Maybe it's just me but I think it's absolutely retarded that I to have order Spicer ball joints because not a single damn parts store carries them.
Isn't that the truth and then some.
On a completely different note, how do I "like" someone's post on here?
Edited by The_Hammer
bottom right of the post corner should be a "like this "button.
oh you are on your phone,
Let me look
humm mine shows "like" in the bottom left on my phone.  What phone are you using?  What does the "+" do?
Edited by Me78569
Mine also shows on the lower left
The "+" is a multi-quote thing.
I'm not a paying member yet and yall' are, maybe that's the problem?
maybe,
I looked through the settings, but I didn't see any permission for it.  Ill dig some more.
