- Replies 24
- Views 12.7k
jigdog 10 posts
notlimah 5 posts
Mopar1973Man 3 posts
Vais01 3 posts
Ok so all seals at the fuel return TEE have been replaced? THIS part from Geno's? Return lines at the FASS are as tight as they can get? FASS filters are tight? Sorry if this
Ok guys could use some input. My truck is y2k 24v auto with a fass 95 lift pump and an reman vp44. If I parked it up hill it has to be reprimed in the morning . (Starter bump type) I put in a check valve on the discharge side of the lift pump by the tank which solved the priming/drain back issue, but I don't know why the fuel was draining back. I have no leaks and no
smell and run 14-16 psi on the fp gauge. When the truck is at lower rpms under load light or heavy I can feel a little bit of surging like a miss. All of the return lines seals have been replaced already . If there's is a leak how can I find it and could it be in the injector pump check valve. Thanks for the help
Edited by jigdog
