- Replies 13
- Views 17k
Cowboy 5 posts
Mopar1973Man 3 posts
JAG1 2 posts
dripley 1 post
So I hear some people running atf+4 for power steering fluid has done them well then others harshly say not to use it. Well I can not find any synthetic power steering fluid around here and I'm wanting to flush the system this weekend. I want to know for sure the difference between the two and pros/cons of using either. I just installed a new redhead steering box moog pitman arm and tierod and the seal is already leaking on the main output shaft....lmao...within 150 miles![]()
