- Replies 36
- Views 8.6k
stevens cummins 18 posts
dripley 10 posts
CSM 3 posts
Dieselfuture 2 posts
While the fuel pressure is not terrible it could be better, but I understand financial limitations. Bare in mind that most low fuel pressure lights do not come on until about 5 psi or less, well into
If you don't use any 2 cycle oil in your fuel try it 1 oz to gallon, make sure it's ashless. And in your case try a bit thicker mix, might get some more life out of it until you save some money for ne
The 2 cycle oil is a good suggestion. Super tech from wall mart fits the bill. The 216 code is not death as some describe, but is just a matter of time. Who knows when. Where do you hale from Steven?
Ok guys I have a 2000cummins and it was running great till today I started up a grade in 598th gear no issue till half way up it started stumbling only at 1800 rpm and up while in the throttle so I turned around and took it home and got the car and did my running well after I returned home I started it back up and it stumbled for a few min at idle and cleared up till I raved it to 3000rpm and it started stumbling and blue smoking and right befor I let off it poped in the exhaust. It also has 14 psi fuel pressure and no cel what could be causing this?
