Sick, trans is acting up, and I need my truck in the morning
- Replies 18
- Views 6.2k
The_Hammer 11 posts
Me78569 3 posts
Mopar1973Man 1 post
isaac hall 1 post
If you are looking to dive into the tranny I would suggest you ask Dynamic for his recommendation, he is VERY knowledgeable about this type of stuff.
I think it was on purpose to be honest. Before all this I was having issues with my converter slipping so I took it back to the shop (before I knew better). I was told my converter was shot (rem
Just a final update: I finally got the T/V cable adjusted and my shift timing is very nice. All of the issues that I had before stopped once I installed the new VB. My shifts are quick, firm, yet
Thought I had my trans sorted out but unfortunately that's not the case. Currently the TV lever on the side of the trans pushes back so hard I'm unable to push the throttle pedal down much beyond idle. I'm unfamiliar with how the TV interacts with the VB so I have no idea what could be causing this. I need to know if this is something that I would be able to fix tonight or if I'm just screwed.
Edited by The_Hammer
