- Replies 51
- Views 11.8k
catnhat 17 posts
Me78569 9 posts
JAG1 6 posts
Mopar1973Man 4 posts
I would trace the wires coming out of the raptor, then check power at that plug, while idling, to verify that you have 14v. For any large amp draw ( raptor pump) you should use a relay,
Get a FUEL BOSS. No wires, no fuse, no relay, just FUEL PRESSURE. .
Don't plug it into the wall though. Just use it as a jumper from the battery!
When i start the truck I have fuel pressure after about 15 seconds the lift pump shuts off and lose all pressure. I still have the wait to start light coming on i wanted to check the wire out of the ecm for power to the pump but I am not sure which wire it is. Any help would be helpful
