Stupid fuel pressure gauge question
- Replies 10
- Views 3.5k
Mopar1973Man 4 posts
gassernomore 1 post
flman 1 post
IBMobile 1 post
Finally got my FP gauge installed correctly. Had been using the isolator but I could never get it to work right or for very long. Now I am direct to the gauge. 18.5 @ idle 16 @ wot. Stupid questions. If I start to notice a drop in pressure do you just pull over and shut it down? I think I read it takes 14 to open the overflow on the IP to cool the IP. So less than 14 you pull over and shut it down ? I know that sounds dumb but now that I have the FP just want to know what it is trying to tell me to do. If your LP went out completely the reading would be 0 correct ? You shouldn't be getting a reading from the IP sucking the fuel correct ?
Thanks Rob
