- Replies 99
- Views 12k
ruedger455 50 posts
Mopar1973Man 18 posts
dripley 11 posts
Me78569 11 posts
Lock and unlock is the alternator. I would pull the alternator have have it tested for AC noise. The P0122 is just a lo volt code for the APPS sensor. Typically this would make for a dead pedal m
You can pull the fuse on the alternator and see if that helps. It will just run on battery power then and take the alternator out of the equation.
Another thing to check out is all the connections to and from the alternator. Up there in the rust belt especially. Check the field wire and the feed wire from the alternator that routes from the al
Today i went out and popped my hood to check the oil and noticed my drivers side negative battery cable was unhooked like it came loose. I thought i fixed my apps when i reset it but i must have just forgot to put the negative cable back on the battery. So is my rapid studdering a bad APPS? or is it a bad alternator? I do have the p0122 code and it cleared while the cable was unhooked. I dont wanna replace one and have it be the other. But while the negative cable was unhooked i didnt have any issue with my shuddering. Im kinda stuck until i figure this out.cause i cant drive over 50mph without it shuddering like crazy. Any help would be greatly appreciated.
Thanks, kimber
