- Replies 20
- Views 4k
Millfire517 8 posts
Buzzinhalfdozen 4 posts
Mopar1973Man 2 posts
dripley 2 posts
I just got done doing an inspection of my truck and come to find out I had a small fuel leak. So I power washed the engine bay clean since there was fuel everywhere. Now let it dry over night.
Truck started to start real hard yesterday and by the time I've done all my Christmas running it now has a good size leak up near the injector pump. If i let it run for about 5 minutes it has a pretty good size spot on the ground. I can't really see any wet fuel lines but it's definitely dropping down on the front diff. Could my injector pump itself be leaking? It does have an airdog pump on it but like I said I don't see any fuel on the lines.
Got any suggestions?
98.5 24v if that helps any.
Edited by Millfire517
