- Replies 17
- Views 3.6k
CSM 5 posts
The_Hammer 5 posts
Mopar1973Man 3 posts
dripley 1 post
Should run at least a hundred bucks.
Mine is correct, though I need add an update to it. You can use everything from my article on a 00-02 EXCEPT for the pitman arm side tie rod end. The tapered hole in 00-02 pitman arms are a different
@The_Hammer Here is what I found. 94-99 old style taper knuckles and pitman arm 00-02 trucks have new style taper in knuckles and pitman arm 03-08 trucks have the new style sam
I've been given the green light by the owner to work on the next truck. I've got to share this with you all very nice looking 2nd Gen... I had to dig it out of New Meadows, ID. It was buried rather nicely with quite a bit of snow on it.
I know I got to do front end work. Sloppy steering. 4WD doesn't work (vacuum issues). Shocks are worn out and got some bounce and sway. Got it home for the time being that is the first step.
