Guess What I'm doing this weekend?
- Replies 25
- Views 6.3k
Marty "Ghozt" 6 posts
Mopar1973Man 5 posts
TFaoro 4 posts
Me78569 4 posts
Cracked injector bodies don't generally lead to piston failures, but they can lead to too much fuel in the oil which will damage bearings and the like. Injector nozzle and stuck injectors are wh
because user are not always able to see into the download section, downloads are only open to those who donate to pay for the bandwidth. It
That's the problem there is not set number for compression on these engines. More or less as long as it not excessive blow by and ejecting oil out the vent tube then it should be fine. &#
2005 5.9 24 valve. Making oil... Yuk. I guess most of you know what that means. It is also knocking on injector 5 and 6.
At least it is going to be a beautiful day down here in Texas. Already in the 70's.
Will update when I'm all done.
Oh, and this is my first post, great site from what I've seen so far.
Edited by Marty "Ghozt"
