- Replies 37
- Views 6.2k
Dynamic 13 posts
notlimah 8 posts
Me78569 6 posts
Mopar1973Man 5 posts
If I did, I apologize. I definitely WILL be a vendor, but just haven't done so yet... We're still adding products to the site, and have yet to get the shopping cart function in working order, but
Haha... I hear ya. But, luckily for both of us, I do...
I'm actually working on a fix for this right now... What you're feeling is the transmission upshift to 3rd gear, lock the converter, then briefly unlock the converter for the shift to 4th, then r
Alright guys so wanted to start a new thread about my transmission on the 02. I'm not even sure this is an actual issue, but being that the trucks new to me, I'm just trying to figure out if it's worth worrying over or not. So if it seems like I'm chasing nothing, I'm not trying too, just want to verify it's nothing before I ignore it and move on and it turns out to be a bigger issue I could've prevented.
So, what's happening is when driving with O/D on, the truck will engage 3rd gear lock up around 38-40mph, then as speed gets up to 45ish, the trans seems to shift into 4th and attempt to lockup all within like a 1/2 second (and a slight jerky feeling) and then resume back to normal unlocked 4th gear pulling, then around 50ish it'll lock up 4th and everything's good.
I drive like a gramps (if I haven't already made that clear in the past haha) so I'm not sure if I'm just not accelerating fast enough and I'm just confusing the trans. I don't know if it's the bigger tires. It seems to only happen when I'm going up an incline accelerating fairly slowly, or on flat ground accelerating the same. It also seems to be far less noticeable if I'm accelerating quicker, or going down hill. It's almost like the truck gets confused about which gear to be in and whether or not to lock up or not but only during the conditions stated before.
Is this anything to worry about? Is it really just my driving style and certain conditions that are causing this or should I look into something further?
Thanks in advance guys!
