What else should I do?
- Replies 47
- Views 11.3k
dodgedieselnewbie 19 posts
Mopar1973Man 12 posts
leathermaneod 4 posts
BBHD 2 posts
Thanks! it's a work in progress. I haven't even cleaned it since I took ownership lol. I've just added a few things and had the valve cover and intake horn powder coated...
Sounds like you have done quite a bit to it. You ought to take it out and enjoy it.
Yes. Keep it! Doubling up the filtration doesn't hurt one bit.
I have been dumping good bit of $$$ to make this truck the best it can be.
I recently got the front end in order.. removing leveling kit, poly bushings in upper and lower control arms, new track bar, steering box and brace.. added a deep trans pan and gauge.. new injectors.. brakes and lines all the way around including the Chevy 1 ton cylinders.x
What can/should I do to my truck for performance & reliability.. besides routine/preventive maintenance? That's a given.. Most importantly for towing my camper anywhere I'd like to go (long distance.) Getting an exhaust brake is high on my priority list.
Other things I'm thinking about are.. an oil bypass system, larger rear diff cover and traction bars.. but not sure these make sense?
The previous owner disconnected the original fuel filter assembly on the side motor and i was thinking about removing until.. I think Mike mentioned that I should hook it back up for better filtration.
Your thoughts and suggestions welcome!
Edited by dodgedieselnewbie
