Smarty w/ auto trans
- Replies 17
- Views 3.4k
Mopar1973Man 6 posts
TFaoro 4 posts
CSM 3 posts
notlimah 2 posts
Popular Days
I can send you my smarty if you'd like to try it before dropping a bunch of money. If you don't like it, send it back and find something else. If you do, you can run mine until you find a decent price
I run a Smarty and 100 hp injectors, and really like the combo. BUT, I also have my valve body set up for the low end fueling of the Smarty. To elaborate on Mike's point, one of the problems with
Well there is a way to bench test a Smarty...
Well like the title states, I'm curious on your guys opinion on running a smarty with an auto trans? Obviously until I get my trans built, it'd be run on the lowest of settings or off.
To me the smarty isn't just for the tune ability but also to be able to help others clear codes, set high idle and things like that.
Only concern was I've heard it can be pretty smokey on autos and I'm not trying to drive around a smoke machine as my DD!
