what grease to use where.
- Replies 9
- Views 4.4k
Mopar1973Man 3 posts
notlimah 2 posts
CSM 1 post
IBMobile 1 post
Popular Days
https://www.etrailer.com/faq-grease.aspx all the infro you need on grease really, if i only had only one type of grease it would be the red moly high temp stuff, if its good enough for wheel
Anything that has a zerk fitting. Then the things that don't have zerk fitting I've got a true grease needle. I can carefully insert to the rubber boot and refill boot with grease it fills out
Molly, lithium, hi temp. etc.
So what grease is used where? i currently have a molly grease in my grease gun. is it safe for say u-joints? ball joints? CV joints tractor pivot joints. wheel bearing?
i've read and read on this and can't really fin d a good answer. just that new grease is better then none.
anyone care to explain. i have a case of JT-6 extreme hi temp and pressure red stuff but was told by a few people that molly is the best going.
what about the Lithium? where would i use that?
The way one reads most forums i'd need 12 grease guns... i have two but only ever grab one.
