Transfer case out put seal
Hay guys could you give me a national seal number for the the transfer case output I'm 99.9% sure mine has the np241DLD but everyone keeps giving me the larger seal I'm assuming for the DHD
  • Replies 12
  • Views 7.2k
  • I am seeing it as a 4333N  national.    Found that in a Timken cross reference catalog.  I attached a copy.   Search for 4333N.  you will find a GM and chrysler cross.  HTH Hag NSCO
  • stevens cummins
    stevens cummins
    No no leak just had to pull the drive shaft for joint replacement, if you have a leak check for drive line vibration. Plugged transfer case vent. Or play in tail shaft of tc
  • Unfortunately leaking tail shaft seals are common.  I've been through a few and I still get a slight weep.
use the part number lookup too.  or the np241 dhd rebuild.  DHD will have a pto cover dld will not.
Part number lookup
You are talking about item # 1 correct?
Edit:
Well maybe not  I have PN :  04746258 too.  both PN's look to work for 1500, 2500, 3500 according to the part nunmber too though.
looks like Quad4x4 says
04746258 is for dld
04741920 is for DHD after 1998.  So something happened in 1998 that changed.
Edited by Me78569
04746258  is the mopar Part number.  Can you just give that to whoever you are getting the seal from?
HTH
Hag
NSCOilSeals410027to9Y9895.pdf
Can you simply remove yours and take it with you to cross compare?
I didn't want to pull it till I had one I have to have the truck its all I got to drive right now, but the 4333 did work thanks for the help guys. This seal is for the np241 dld
  • 2 months later...
You weren't by any chance having a leak were you? I currently have a leak right at the output seal on my DHD. Not sure if changing the seal will fix the problem or not.  FSM states.....
