Mountain towing
I'm moving to Eastern Idaho  in the very near future and was wanting to upgrade my stock injectors for a little more "I think I can" power, for the Teton mountain range. I talked to a fellow at DAP about some 7x0.0085VCO injectors and he said I would be fine with stock HX35. But if I wanted to upgrade the turbo he suggested a Screaming Eagle 62/68/12 turbo. I've done a few web searches and all hands back his statement that I'd be fine, even running my smarty.  For those of you who live in the mountains what are your opinions? I'm open to suggestions, as long as its not BD parts. I don't anticipate towing much over 8000 pounds.
  • Replies 17
  • Views 4k
  • Sounds like decent advice. DAP are good folk.   I still like the he351cw as a all around turbo for that kind of work/fuel but its not a drop in. A custom 60mm would be nice ....... thin
    I'm towing close to 8,000 pound typically. I'm just a small +50 HP injector still running HX35W turbo with no EGT's issues even with 3" straight pipe exhaust (muffled). Take your pick.... I'm just on
  • I was up in that area last spring towing my 8,000 lb 5er with no problem on a stock turbo with an Edge EZ and a boost elbow.  I had no problems go up or down the mountains.
A custom 60mm would be nice ....... think fleece make one ........
I'm towing close to 8,000 pound typically. I'm just a small +50 HP injector still running HX35W turbo with no EGT's issues even with 3" straight pipe exhaust (muffled). Take your pick.... I'm just on the west side of the state. Normal forestry grades can be 16% or so. No issues.
I tow with the Industrial Injection 62/12 and DAP 125 SAC injectors.  I use a smarty as a towing programmer.  All in all I really like the combo.  If you have a normal stall torque converter it should tow good.  The 2-3 shift is kinda wide for the turbo though, and it will bark on occasion.  Not much you can do about that other than add fuel and live with some haze across that shift.
The combo will really wake up with additional fuel.  With the smarty/tst stack it is pretty fast for an old truck.
The vgt likes the mountains.  No issues with my 7x.oo9s. And quad
For all around,  you probably have the sweetest setup.
If I only had a triple disc and billet input....he451ve would be on my list.
It is running really well now though, couldn't be happier.
What are the dimensions of the 451?
Comp
64 inducer
93 exducer
turbine
76 inducer
67 exducer
Only thing I don't know is if the exhaust side can close down enough to act as an EB on our trucks.
8000 is nothing for these trucks in stock form.  I only have an EZ and RV275's and I can tow my 14k-15k 5th wheel pretty nicely in the mountainous northern CA.  Usually able to keep it in 4th gear too.
3 hours ago, Me78569 said:
Comp
64 inducer
93 exducer
turbine
76 inducer
67 exducer
So other then the possibility of an EB not working, the 451 is a straight drop in??
No you need the right exhaust manifold and downpipe.
for me it would be drop in because I already have a he351ve.
Do you just use the exhaust manifold off the appropriate truck and that's a bolt on for our trucks?
Thanks for the replies guys, I have a 300 rpm lower than stock  triple disk torque converter, with billet input shaft. I'm gonna call DAP here in a few and order those injectors.
Ok, dumb questions...
  1. 6.7 manifold drop in for a 5.9 truck?
  2. What are 451s going for these days?
After seeing your adrunio controller the other day, I really wish I had done this rather than my 62.  For my dad's 3rd gen Rams, that adrunio controller and a 451 would be SICK!
A he431ve would be comparable to your 62.........
a he451ve on a cr truck would be freaking awesome.
you can use a 6.7 exhaust manifold and just block the egr stuff.  it will bolt to a 5.9 engine.
Auto trucks would have to have the tranny heat exchanger moved as the cr exhaust manifolds place the turbo right where our trucks heat exchangers sit.
