- Replies 17
- Views 2.9k
Me78569 5 posts
CSM 4 posts
Mopar1973Man 2 posts
notlimah 2 posts
Popular Days
Sounds like decent advice. DAP are good folk. I still like the he351cw as a all around turbo for that kind of work/fuel but its not a drop in. A custom 60mm would be nice ....... thin
I'm towing close to 8,000 pound typically. I'm just a small +50 HP injector still running HX35W turbo with no EGT's issues even with 3" straight pipe exhaust (muffled). Take your pick.... I'm just on
I was up in that area last spring towing my 8,000 lb 5er with no problem on a stock turbo with an Edge EZ and a boost elbow. I had no problems go up or down the mountains.
I'm moving to Eastern Idaho in the very near future and was wanting to upgrade my stock injectors for a little more "I think I can" power, for the Teton mountain range. I talked to a fellow at DAP about some 7x0.0085VCO injectors and he said I would be fine with stock HX35. But if I wanted to upgrade the turbo he suggested a Screaming Eagle 62/68/12 turbo. I've done a few web searches and all hands back his statement that I'd be fine, even running my smarty. For those of you who live in the mountains what are your opinions? I'm open to suggestions, as long as its not BD parts. I don't anticipate towing much over 8000 pounds.
