Automatic Transmission Cooler Lines
The sage of the leaking cooler lines continues.  In Dec 2014 replaced the hard line from the cooler to the transmission, it started leaking. Thought it was the rubber hose with the PITA connector. Bought a replacement from NAPA, it leaked worse than when I started. Took it back apart and found it cracked by the ferrule in the hard line. NAPA replaced it under warranty. Now the line from the front cooler to the block mounted cooler is split. The replacement line is 95.00 NAPA/ 67.00 AMAZON.
Just frustrated. Anyone changed out all the line for something different?
  • Replies 12
  • Views 5.2k
  • banzaitoyota
    banzaitoyota
    HOSES ARRIVED VERY QUICKLY
  • Been there, done that.  finally replaced all the hardlines with this softline kit.  the vibration of our cummins really tears up the metal lines.
Edited by Me78569
7 hours ago, Mopar1973Man said:
Gotta check the site store once in awhile you never know what we might be selling these days... :whistle:
LAst time I checked, you said it was in development:smart:. Sent a PM a couple months ago inquiring and no response.........
Pm's slip through the crack when you get a wave of them each day.  Your questions are better asked via a help ticket or here on the forum where more than one set of eyes are watching.
Exactly.
Let us know what you think and how the install goes for you.   This is based on what I have in my truck and the hose lengths ETC should be good, but I am always nervous.
