Automatic Transmission Cooler Lines
- Replies 12
- Views 5k
banzaitoyota 4 posts
Me78569 4 posts
Mopar1973Man 2 posts
Buzzinhalfdozen 1 post
The sage of the leaking cooler lines continues. In Dec 2014 replaced the hard line from the cooler to the transmission, it started leaking. Thought it was the rubber hose with the PITA connector. Bought a replacement from NAPA, it leaked worse than when I started. Took it back apart and found it cracked by the ferrule in the hard line. NAPA replaced it under warranty. Now the line from the front cooler to the block mounted cooler is split. The replacement line is 95.00 NAPA/ 67.00 AMAZON.
Just frustrated. Anyone changed out all the line for something different?
