Edge comp, mild injectors, fuel mileage
Hey guys,
so I've had my edge comp for a little while now and I'm starting to experiment with settings for fuel mileage. I also have 75hp injectors. On 3x5 I got 17.5 over the course of a week. Then I tried 5x2 because of what Mike said in the past about 5x5 being best, but I had to use 5x2 to keep smoke in check. I will be filling up today, but so far it looks like I got right about the same for mileage. Shouldn't I have gotten better? My route and driving style didn't change....
I also read some really old threads on other forums that were talking about unplugging the wire tap to get less fuel and more timing at the higher levels. Is this something I should try?
Anyone with a similar setup to mine have any recomendations?
I should also add that I'm hoping to get some new injectors in the near future. My truck came with the BD diesel 75hp that are in it now and I haven't heard the greatest things about them. I'm thinking RV275s for my next ones unless anyone can recomended something they think is better....
Edited by leathermaneod
  • Replies 34
  • Views 7.8k
  • 7x.012 is big. That's ~ 250hp There is also a difference between sac and vco nozzles. Typically sac flows more, so the same size holes flow just a bit more fuel. I'd go right around where yo
  • Dieselfuture
    Dieselfuture
    I got a qwadzilla and it has level one which is all timing and considered to be for best mpg, that's why I don't understand why you'd get better mpg by fooling iat to think it's hot out 143f which ret
  • You can try it, but it comes more down to driving style than edge settings. The edge just squeezes the last little bit of mileage out.   As for injectors, RV275's are good. DAP also makes qu
Go with DAP. Chris hasn't gotten back to me about my current injectors, via email or phone. My new injectors just came today from DAP
That's sad to hear.  If Chris isn't getting back to people then DAP all the way.
Thanks again for all the help and advice guys! I will most likely be going with DAP when I get the funds for these. Gota do some saving up because I'm already planning on the new steering setup from synergy when it come out in August :cool:
also incase anyone was wondering, I filled up this afternoon and I got 18.26 on the tank with the comp on 5x2. This tank I'm testing out 4x4.
I would go up it 5x3 or 5x4. Trying to stay out of the defuel mode more.
Sublevel
1. 33% of stock fuel till 20 PSI of boost pressure.
2. 50% of stock fuel till 15 PSI of boost pressure.
3. 67% of stock fuel till 10 PSI of boost pressure.
4. Some extra fuel at low boost.
5. Full fuel at 0 PSI boost pressure.
With that being said 5x5 typically netted me the highest being there was no defuel map also was the hardest because it was up to me to hold back on the throttle till about 10 PSI at then lay into the throttle.
Correction I missed one value...
I appreciate the tips! I was playing around in the 5x range on the last tank before settling on 5x2. It seemed to smoke quite a bit above 5x2, that's why I went lower on this tank. So far 4x4 seems fairly clean and spools decently quick. I don't go above 10psi of boost much in my daily driving. I don't even get to 10 psi that much...I think I really need a cleaner injector :sleep:
what at is the purpose of the comp limiting fuel below stock levels?
It's not limiting the stock power, but rather the amount of power added on top. So if you're on level 5 (120hp) and sub level 1 it'll only give you 40hp above stock before you get more boost.
That makes way more sense now! Thank you!
Sublevels are design to give 3 levels of smoke control. Problem as you enter the defuel mode it seem to lose the timing and performance bonuses in the defuel mode at least on my truck. Once above the defuel mode now the timing and everything seem to be in full swing. Sublevels 4 and 5 are powered levels with little to no limits on fuel and timing so it much more aggressive.
@TFaoro is right the main level is just limiting you max fuel at WOT. That's all...
well now it looks like I'm finally gona have to tackle my vacuum pump instead of getting new injectors lol. Starting to leave a really good puddle. I'm just hoping the timing case to block gasket isn't part of the problem.
Vacuum pump rebuild is only $13 buck for the seal kit. That should stop you from buying injectors.
Yeah I got one on eBay for $17.50. Local cummins service center wanted $16, plus $10 for freight since they had to order it. No the price isn't stoping me, more just the time right now. Gota try and get some more use out of this truck before putting more into it. Ive spent so much in the last year and a half its not funny. When I bought it I figured, "it has a cummins, 248K is nothing". I didn't realize all the other odds and ends that come up on a vehicle with that many miles. Plus my OCD over little things hasn't helped. Then my poor decision to get a shop to do some work on it instead of tackling it myself. What a fiasco that was. Anyway its been a learning experience. I get carried away dreaming about the next mod, injectors in this case, but in reality I don't "need" them right now, and I need to save some $ too lol. I plan to do them ASAP, just not sure exactly how soon that will be.
Don't forget about Power Driven Diesel for injectors. They have their Budget Builder sets for around $300. I just put a set of 7.009 in a 94 12v with over 1.3 million miles and the owner said they ran great, smoother than the stockers i pulled out. I have also ran 7x.010 Contagious Diesel in my 24v and they ran great with great customer service. This new set of 5x.016 from Infinite Performance I just put in my 95 are smoother than the JL Machine 5x.012 and stockers i pulled out.
If it makes you feel any better, I just averaged 17.0 mpg, hand calculated, lots of city/in town driving, 100hp injectors and 285/75r16s(33s). So if the speedo was corrected the average is probably more. I can average 20+ mpg highway only.
Might want to look at my pass fuel logs... I just had to see if I could still do it. Yea... I can smack a 26.59 MPG for the day...  Again the higher number are always going to show more so at lower speeds. Like all my 20-21 MPG are all running speed limit.
