Leaking Fuel Connections
- Replies 12
- Views 2.8k
leathermaneod 4 posts
Hawkez 2 posts
Me78569 2 posts
notlimah 2 posts
Popular Days
I use this on just about all my npt fittings, especially after the fuel filter. it is expensive, but a little goes a long way and it believe it is the safest option for this if you need a th
Eric definitely uses it, I've chatted with him about this several times. Fass recommends against using a liquid thread sealant and to use the thread tape. I prefer the liquid type and since Eric gave
I have a weeping connection where my needle valve goes into a Tee. Is there something I can put on the treads to seal that? It is just enough that if it sits for anytime I have to bump the starter to prime the system? I have tightened it down as much as I'd like, anymore and something will give.
