Turbo oil return hose
Anyone know what size hose is required on turbo oil return. Mine looks like it's getting kinda porous. Is it something special or just a chunk of oil resistant hose. Thanks
  • Replies 12
  • Views 3.5k
Not sure what it is. I could just be leaking at the gasket on the turbo. Mine is weeping and has worked it's way down the hose.
7/8" ID. Hard hose size to get locally. CPP diesel has it, expensive. Look under turbo oil return lines.
Have fun changing it. Get a turbo to pipe gasket,. When I changed mine I cut old hose off but could get new one on until removed the flange to the turbo.
Oops! You're right! I read the description wrong and sometimes Vulcan's pics aren't always right. My bad! :doh:
I appreciate the effort notlimah. It does say bottom, maybe for twins?
Edited by Royal Squire
On 9/7/2016 at 9:13 AM, Royal Squire said:
Pipe is dry, just the short hose looks oily
Mine is exactly the same way lol been wanting to take care of it, just haven't got around to it yet
Yea I'd imagine for twins or a different turbo.
