VW TDi.. need an education!
- Replies 15
- Views 14.2k
Dieselfuture 4 posts
Wild and Free 3 posts
dripley 2 posts
rancherman 2 posts
Never had any leaks on ours even @ near 300K, was about due to have the OEM clutch replaced which was still working good but could tell it was getting stiff which is usually the first warning sign of
I know there is a few guys in here that have run the 1.9 Tdi.
I need a quick low-down on what's-what. TDi for 'dummies' if you will
Please explain the differences in what I'm seeing; ALH, BEW, AAZ.. American side, Canadian side configurations... etc etc. all of these run egr?
Mechanical versions.. and computer managed.. years made..
Immobilization enabled versions... I suppose those were built from the low 2000's onward, Probably the exact versions to stay away from in a 'swap' scenario..
I've seen some 'tuned' to around 150 hp, and still reliable. Your thoughts?
