- Replies 13
- Views 2.7k
KATOOM 4 posts
IBMobile 3 posts
JAG1 1 post
Buzzinhalfdozen 1 post
In the above diagram, the fuel pump will only work when the starter motor is being engaged and pin # 85 is energized. What else is energizing pin #85 when the starter motor is not being used? Also t
After I installed the Fuel Boss and an Airtex pump I disconnected the Airtex. This set a p code in the ECM and when it was time for the 'smog' inspection it would have failed. The problem was solved
You guys say i need a fuel pump relay. I buy a new relay and understand all the wiring to it. Crawl under the truck and find 2 wires going to my fuel pump. ! red and 1 black. OK find the ground. Use ohm meter, both go to ground. Fire the truck up and red reads 13.9 and black reads .3. Check black with ohm meter and it does not show ground. ?Probable goes to ground through computer?? Do not want to screw anything up! HELP?
