Questions on Airdog pump install or "re-install"
- Replies 4
- Views 1.9k
Mopar1973Man 1 post
dripley 1 post
Me78569 1 post
01cummins4ever 1 post
Started working on my Airdog pump and low pressure fuel gauge today. Pressure tested at the Airdog port and it shows 21 ½ pounds on one of Vulcans gauges. I’ve read people like 15-17psi . I assume the psi would be the same closer to vp44.
Question 1…Is 21 psi OK or is it too high and might damage pump? Model of pump is DF 100 which I think is not adjustable, but not 100% sure.
The pump is mounted with the fuel line from Airdog just the way they ship it and was not cut to fit. So pump is about ½ way between VP44 and sump at tank. To take up the slack in the fuel line, the guy put a circle bend in the line under the airhorn and already chaffed. Line is also rubbing on the frame at several places on frame. If I put the pump on outside of frame there is lot less to rub on. But I have to raise pump about 8 inches (pumping up hill usually not good for pump I know) The bolts holding pump in place are almost finger tight. If bolts to mounting bracket were tight, looks like they will smash the brakelines. But I could put in a spacer of some sort. But would prefer to mount airdog on outside of frame and extend fuel line to vp44 and shorten fuel line from pump to tank.
Question 2…Are these pumps better at pushing or sucking or does it matter? And going vertical 8 inches might be a “drag” on system or would it be?
Thanks
Edited by 015point9
