Can anyone solve my mystery clunk
So @KATOOM wants to know more about my mystery clunk.
When unloaded I have a pretty nasty clunk/crash that can be felt in the floor.  Steering doesn't seem to be effected though.   It is directly related to when you unload the front suspesnion.
From the drivers side it feels like it is coming from the passenger side, from the passenger side it doesn't feel as bad.
Before we get into what I have replaced we need to look at the history of my truck, the PO must have broke the front axle as i have a 1994 d60 under the front rather than the 2000 that I was supposed to have on the truck,
Things I have replace that made no difference,
- ball joints, all of them
- steering assembly, 2x
- control arms 2x, upper and lower with new hardware and welding the caster adjuster in place, now have adjustable control arms due to that.
- control arm bushings 3x
- body mounts,
- sway bar mounts and bushings
- sway bar end links front and back.
- wheel bearings
- shocks 2x
- track bar 3x
Things I am wondering about still,
Motor mounts, doesn't happen when I get on the skinny pedal though.
ovaled out body mounts for the control arms.
So who has the magic answer to my clunk?  I rightly dont care anymore. after 4 years of the clunk I just couldn't be bothered to fix it lol.
Edited by Me78569
  • Replies 71
  • Views 13.3k
  • Buzzinhalfdozen
    Buzzinhalfdozen
    Based on what you've checked and replaced I wouldn't think it's a driveline/suspension issue. You should start looking at weird things like: Loose or cracked crossmembers.    Broken spo
  • Damn it ME now I am starting to hear a clunk under my passenger side now. Mostly bumping around on the job. Not so much on the road yet. Everything on my front has got little over 100k on it so maybe
  • Well to add another chapter, I did go ahead and replace ball joints again.     My uppers did have a touch of play in them. I wouldn't consider them bad, but hte alighnment shop did.
The clunk feels as if the axle is shifting.  it is by no means a same clunk.  Had  I not been under the truck 1000 times looking for it I would be worried the axle was going to fall off.
But I can unload the font suspension and pry, wiggle, hit, kick, bounce, etc and everything is tight.
body mount? shock bushing loose?
i had the lower shock bolt fall out of my 04 when i first got it. sounded horrible.
i havent read the thread, maybe i should....
ok so i've read the thread.. more thoughts. have you done the PCV re rout? is it hitting the cab?
the t-case mounts letting it bump the cab? is your floor shifter? enough clearance?
bump stops?
wheel bearings?
My best guess at this point is my body mounts are fubar'd and that is the issue.  I have checked and replaced the bushings, but who knows.
Shocks bolts are tight.
pcv reroute, but it had the clunk before and after and while it fell off lol.
tcase was hitting the cab, but I fixed that, clunk before and after.
bump stops are looking good, plus there is no way the suspenesion would flex enough to hit hte bump stops at 5 mph.
Wheel bearings are new and tight.
Edited by Me78569
So then I'm going to assume that the clunk noise is constant as you drive around and not just every once in awhile on certain bumps.....
all the time,  could be a crack in the road or a man hole cover or a pot hole from hell, the clunk is there reminding me how much I hate chystler products from the 90's
The dry shift linkage clunk was like someone lightly tapping the floor board under the steer column with  small ball peen hammer, not a big clunk just an annoying one that varied upon road conditions, packed grease into the areas i posted took care of it for me. I have also seen where the adjustable steering links were not adjusted to where the tie rod ends were in a neutral 90* position and they would cause a clunk as well.
Broken spot welds on the cab mounts or floor boards.
Steering column bushing.
Lift pump dangling by the fuel lines and banging against the frame. It happens...
Spare tire banging around, sound can travel in strange ways.
Full coverage and a well planned fire.
Something rolling around under the seat. Sometimes we overlook the simple things!
have a go pro? mount it up an some odd places and drive around a bit.
Can't be telling people my plan in public hahaha.
Nah I don't really care enough to put more money into it.  If the wheels haven't fallen off yet I have accept it and keep driving.
I really think it is just ovaled out holes and beat up body mounts.
6 hours ago, Wild and Free said:
You have an auto as well..................putting a pattern together here. Have you checked the shift linkage rod like I posted about above?
I have not checked that, ill try looking at it this weekend, i did notice when i had my tranny rebuilt by a local shop it did it alot more..
6 hours ago, Me78569 said:
I have thought about the coal springs also, maybe the rubber isolators are bad?
Track bar is tight, check and rechecked, even used a jack to tighten the bolt down haha.... I've had someone crank on the wheel back and forth and I watch the track bar.
It is a Rayebestos pro track bar along with all the other parts under the truck.
Replaced all of the bushings in that assembly haha.
it feels like it comes from the front end most of the time,but then i get it where my right foot and tranny housing is. i have checked everything on that side, the only thing that i haven't check is the wiring housing under the driver door/quarter panel , i know that sits kinda in a cubby but i would see it moving that much,  i need to check my brake lines, tranny cooler lines
the coil springs keep coming to mind everytime i think about it. i have checked all my cab mounts, everything turns up tight and no cracks that i can visually see.
I'm sure you're right.  But just to be sure, I think you should drop your truck off with me for a week or so.  That way I can drive it around and determine what the noise is.  You know.....for the betterment of the forum.
You are more than welcome to come drive it haha.
I had clunk in mine for while after changing the shocks. Turned out to be one of the front u joints. Of course i would think you would have noticed that when you did the wheel bearings. Thought it was weird that mine only clunked and did not vibrate or something while spinnig, just clunked on a bumpy road. The bearing completely gone out on cup and nothing but crumbs in the opposite one.
ujoints up front are new too, I forgot I replaced them.
Nick, have you checked your caireer bearing or yokes on your driveline? I just replaced my bearing but I don't think the drivelines have ever been changed
I did not see it in your list but figured is was a long shot since you replaced the unit bearings. Found my bad one when doing brakes a few months ago.
stopped my clunking.
Edited by dripley
New carrier bearing and yokes don't budge when I pry on them.
I'm not sure there's anything left to question, and the only things which haven't been checked is the body mounts.
The drive shaft splined shaft near the front  U-joint absorbs  different drive shaft effective lengths as bumps and weights are absorbed by the suspension.  Length changes as angle of drive shaft changes WRT transfer case and front axle geometry. If you changed the front axle this can change things  and spline can hit the stop and give a jolt sensation. Something worth checking? You can disconnect one end and check the travel by pushing and pulling on it as it has a rubber boot hiding the splines visually.
